MAD777
Do I need to use protected batteries in the K40Lvn or should I use my IMR high drain (unprotected) batteries?
Got 'em! 👍Any cells should be fine but I would recommend LG 3500mAh unprotected
As my dad would have said. "It's broke in now"
I look at it this way. I'm spending extra money for a special light. A few more dollars will make that special light more useful. These lights are pushed.
I guess if you're only going to flash it on momentarily to impress your friends, then maybe skip the heat management elements.
By the way, this light has a quirky lanyard attachment. Each of the twin holes on the side of the tail cap can accept the supplied lanyard, but then you can't tail stand the flashlight.
I have discovered a fix! Thread a 1/2" outer diameter split ring into the two holes. Now attach the supplied lanyard to the split ring.
