crazychimpjimbo
- Joined
- Mar 13, 2008
- Messages
- 11
Hi Guys
Been a few years since I posted! Always been into MTB lights so this is something new! I've changed Enduro bikes recently! Gone from a Yam WR with modern dc electrics to a Kawasaki kick only running ac.
Its hard to find some details but a lot of forum talk has suggested the stator/alternator kicks out around 40w. Now my plan was to convert ac to dc to acquire full MOT for the uk. I.e. dim-able lights, brake/tail light etc!
My plan is to install a 12v regulator from the pole on the stator, followed by rectifier, onto a battery pack. The wiring will go to appropriate switches that operate the lights. Now the rear lights are DRC Edge 2, rated at 4.65w at full brightness, i.e. braking. I haven't Decided for sure on the fronts but potentially it could be Trailtech X2 HID kit which drives 70w on main beam.
If I was to go for this setup what battery pack size wise should I be looking into? Would a 12V 3700 mAh NiMH be sufficent or would this drain faster than it can charge? Would I need to upgrade the stator to cope with potentially rounded up number 80w's?
If I have confused everybody just say and Ill start again!
