hello all,
Thank you for taking the time to read. I'm not new to flashlights, but i'm definitely new to this site. I've found that there's so much i do not know. I'm overwhelmed with all the information, and thought perhaps asking was a better idea.
A little bit about me. I served in the military and now am in LE. In the military i carried U.S. Army L Head Flashlight, then the small maglight with the red, blue and clear filter and shortly after i went to a surefire. Now then, I think i need two flashlights. I definitely need a new one, and possibly upgrading my existing primary flashlight.
Co-workers have Coast, Fenix and PolyStinger flashlights. Some are brighter than mine(200 lumens), but most of them tend to have either bulb problems or have had "operator" issues when it comes to the abuse the lights take. Others are bright initially, but don't throw the beam of light... I depend on the light for safety and a requirement for work. So I bought a Surefire.
considering
Zebra Light SC51Fw AA Floody Flashlight
Fenix E05 R2 Flashlight
After carefully reviewing my needs and further research, I found that I need two lights.
I'm keeping my SureFire LX2 and and looking for a flood light.
I need a flood light. To search for "lost" items. I'm in LE and several times I've found myself looking throughout bushes, debris and alleys for various items. I want a flood light that has a decent run time (over 2 hours) I don't' need several settings. this light will only be used for searching. If it has several settings, thats fine. But the flood is what i'm looking for. I work midnights so the light will be used at night.
I've had suggestions of the Zebra Light SC51, Fenix E05 R2, Fenix pd01 and pd15.
I've overwhelmed with all the information. thank you for all your help.
store, online.
2) Budget:
up to $75.
3) Format:
Flood flashlight.
4) Flashlight-specific format/size:
small no bigger than 4 inches
5) Emitter/Light source:
I don't know.
6) Manufacturer:
I really like surefire but am open to your advice
7) What battery type do you want to use?
I'd like to keep it small so no more than 2 AA, AAA or one A CR123 or something similar
8) How much genuine out the front (OTF) light do you want/need
looking for max flood light. doesn't' have to be too far i guess a room's width and no farther than 15-20 feet ahead
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
Flood
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
definitely over an hour preferably over two
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
important…. not critical. it'll be in my vest. some bumps perhaps. want good durability
12) Switch Type and location (choose all that apply):
Doesn't matter
on / off….. doesn't matter.
14)Material/Finish/Coating
NOT cheap plastic…. something that'll last a while
If i can stick to one flashlight, that would be better. But being in the military i'm not opposed
to having two lights. I in fact need to flashlights. My primary needs to be a throw... LX2
and i really need a flood light that is small and compact.
Again, thank you in advance for all the help and all the great suggestions thus far......
considering
store, online.
2) Budget:
up to $75.
3) Format:
Flood flashlight.
I don't know.
6) Manufacturer:
Flood
Doesn't matter
