Keyring Eiger bodies question.....
Brasso
Alabama
Can you still get the Eiger Keyring bodies what aren't drilled all the way through? I really like that style.
MKLight
Yes, they're the lug and pocket bodies. The lug has a permanent keyring attachment and the pocket is flat on the bottom.
Brasso
Alabama
No, that's not what I'm talking about.
I mean the one with the removable keyring attachment, that isn't bored all the way through for a momentary switch. The way the used to make them several years ago. I'm wondering if you can still get one. It's the same kind I currently have in my brass Eiger. You can unscrew the keyring to detach it from your keyring, and it can tailstand. Very nifty design.
jabe1
Cleveland,Oh
Brasso,
I don't think Curt has made those for some time. I've had two bodies like that in the past.
archimedes
Moderator,
Staff member
CONUS, top left
I believe that the change to an adjustable negative post was to better accommodate slight differences in battery length, among AAA/10440 cells....
dudemar
Arnieland
It works fine without a keyring attachment and it can tailstand, but it won't be very water resistant. Then again it can tailstand with a momentary switch too. :)
archimedes
Moderator,
Staff member
CONUS, top left
If you use the QTC pill you can remove the keying attachment and it should still work.
Has anyone confirmed if this works?
Sure, this works fine on mine ....
EDIT - Excellent point, dudemar. I agree that this might compromise the water-resistance. However, for most purposes, I would suppose that use of the tail-standing feature is less likely to be needed underwater :devil:
dudemar
Arnieland
There is a brass/copper screw visible on the Oveready page, not sure if it has an o-ring. That would allow water resistance and tailstanding.
ElectronGuru
Oregon
That screw fits into the inner threads and was needed to provide negative contact on long pre QTC bodies. It goes in to far to be installed at the same time with a pill.
OTOH, there is a screw that fits into the outer threads (think shaved keychain post). It tailstands, supports clip attachment, and includes a full sealing o ring. Just need to get it finished...
manoloco
Lima, Perú
Interesting accesory Dan, it could be made so it supports a keyring too, it would make a GREAT Eiger.
Also could be made so it controls brightness from the tail (with a central stem) but dont see that option too practical for my current uses
dudemar
Arnieland
That's awesome! I'm glad I brought it up, now I know what I want for Christmas! :)
