Our kitchen does not have a window by the sink and the only available lighting is a couple of Florescent tubes in the middle of the kitchen. When working at the sink your body basically blocks direct lighting where you are working.
I decided to use some of the older LEDs since I have gobs of them. Some old Lux3 on stars underdriven at around 150mA runs them at a point where they put out good light and don't get too hot and do not need additional neat sinking requirements. The star is sufficient to dissipate the heat at this drive level.
SMT resistors were used to bias each string of 4 to the desired current.
On the large panels one Luxeon Rebel 100 was mounted and wired to a photo sensor circuit that turns on the two LEDs when the ambient gets dark for night lighting.
DIffused white plastic sheet stock with holes drilled for LEDs and mounting screw holes countersunk for flat heat wood screws.
Under the counter there is a 1/2" trim. The two main panels sit flush on the trim smaller panels sit recessed inside the trim.
DC Power is a Solid State high efficiency Wall wart 15V 1A module with 2.1mm DC power jack connector.
A female 2.1mm Jack is mounted to the main panel along with the rocker power switch.
Close up of the Single Rebel 100lm.
