Hey guys,
I was just rooting through some light stuff that I had and found some of the older type SO17XA reflectors and resistors that I had for doing KL1 mods.
What the mod consists of is the addition of the IMS reflector and, if desired, overdriving of the stock circuit to either 700mA or 1A (I suggest 700mA). I can also replace the emitter, if needed. This won't be necessary if you have one of the newer KL1's with a high dome and you like the tint of it.
If you're interested, PM me for details.
BTW, I do KL3's too. I can overdrive the circuit to around 800mA or 1.2A, swap the emitter and add a 27mm reflector to it. Well actually, the reflector is 27mm before I turn it down to fit into the KL3, but the beam remains virtually unchanged.
I just did a KL1 mod and posted the results here.
http://www.candlepowerforums.com/ubbthreads/showflat.php?Cat=&Number=698807&page=0&view=collapsed&sb=5&o=365&fpart=1
***For you guys ordering mods from me. Please remember to use the note section on PayPal and make sure that you include a description of the mod that you are getting, ie., 700mA, Lux III, 17mm reflector. Also make sure that you include your CPF handle.
***I now have more of everything needed for KL3 mods. If you are interested, follow this link for more information.
KL3 Mod Info
