Klarus XT11 (XM-L U2 - 1x18650, 2xCR123A/RCR) Review: RUNTIMES, BEAMSHOTS, VIDEO+
selfbuilt
Obviously the runtime is poor and I only have 2x AW 16340's. Could I use 2 standard unprotected rechargables 3.7v in the XT11 (I have plenty of these) What would be the advantages/disadvantages? What problems might I encounter? Why would it be a good/bad idea? I know Klarus doesnt recommend it but why?
Instead of two IMR 16340, try two IMR 18350 instead. Its brighter, and runs longer.
I agree with TEEJ - 2x18350 IMR would be the best choice for a two cell setup in the XT11. Protected RCR are not really well suited in this light, due to the low cell capacity and high circuit drain.
What you are risking by going to unprotected cells is the extra safety of the protection circuit during operation. If something happened and one cell failed during operation, that could lead to a bad result quickly with unprotected cells. And of course, there is always the possibility of accidental over-discharge on unprotected cells (which then poses risks when it comes to recharging).
If you use only paired cells from the same batch, carefully monitor the health of your cells (including recharging frequently and ensuring cells always remain well balanced for voltage), and never over-discharge, then you are likely to be ok with unprotected IMR (although failures can always happen).
Lord Muzzy
Thank you for your help @selfbuilt and TEEJ! 2X IMR 18350's it is! I found these on eBay
2 X Efest IMR 18350 800mah Flat Top
I have not heard of this make (but to be honest, I hadn't heard of 18350's) Are they a good battery?
If not could you recommend some that are reasonably priced?
Once again, many thanks!
Nighted
XT11 2014 edition with the updated secondary switch.
I do NOT recommend this version. After less than a month and 4 times used:
