tylerdurden
I got the circuit out of the L1 without destroying it. It now freely slides in and out, but works fine.
The circuit resides in a "coffin" (as Don calls it) in the top of the battery tube. It's a little bit shorter than a 123 cell.
There are 8 barbs on the plastic cap at the top of the L1 battery tube. The four larger barbs can be gently pried inward with a fine-bladed precision screwdriver. The other four are pretty rigid, so I just cut them off with an exacto knife. /ubbthreads/images/graemlins/smile.gif By leaving the four larger barbs attached, I've left open the possibility of re-securing the coffin. You can just leave them pried in, though, but the coffin will slide in and out of the tube freely. This isn't really that big of a problem since the head generally stays screwed on.
(click for larger image)
Upon extracting the coffin, the first thing I thought was "that's it?"
Now if we could just figure out how to boost the output of this circuit. The 1.5 ohm (I think) resistor (marked 1R5) looks similar to the 1.0 and 0.1 ohm resistors that control the output of the KL1 circuit, but I have no clue if the function in this circuit is similar. Since this is the only L1 I have right now, I don't intend on experimenting.
