L2D-CE flashes when switched on
Dr.K
Webster Parish Louisiana
I found the remedy. loosen the head a full turn or so instead of just enought to turn off turbo. the opposing force of your fingers and thumb (while clicking on) are activating turbo mode only until you release the clicky (a split second). check it out.
stamat
I found the remedy. loosen the head a full turn or so instead of just enough to turn off turbo. the opposing force of your fingers and thumb (while clicking on) are activating turbo mode only until you release the clicky (a split second). check it out.
I have to disagree. The pre-flash is there in the low power mode of my L2D, regardless of how many turns.
When my eyes are dark adjusted it is blinding. I turn the flashlight to see something and for a moment my ability to see gets worse instead of better.
:thumbsdow
I greatly prefer my original (Luxeon) L1T :thumbsup:
L.E.D.
Arizona
One interesting thing to note about the L2D CE flash is it is an extremely quick pulse, at least as quick as a nice strobe. If you point the beam right at a ceiling fan that is spinning at its fastest rate, you'll notice the flash "stops" the fan perfectly in one frame. You can also do this continuously by tapping the switch really fast, keeping it depressed for less than 0.2 seconds each tap. It should stay in low mode between each tap when executed correctly. If you're too slow, it will just switch to medium high and strobe, as this actually takes quite a bit of clicking finnese. May be useful for timing cylinders on an engine?
MikeSalt
Stoke On Trent, Staffordshire, UK
I notice something similar with my P1D-CE. When I go from 'high' to 'low' very quickly (it goes med-high-low-strobe-SOS), the low mode comes on a little bright, then tails off within less than a second to normal 'low' mode.
What I can assume (having never opened the head) is that the circuitry is very rapidly pulsed PWM, and this is smoothed out by a tiny capacitor so you cannot notice the dreaded 'PWM' flickering. When you change modes, a little bit of charge is still left in this capacitor from the higher modes. This causes the flash, or in my case, the quick tail-off. It is not likely to be a fault at all.
PegAir
I've wondered if this was done intentionally for the LED. Does the brief intense flash help the LED's color, brightness, or efficiency before being placed back into the lowest power setting?
Using an outdoor "how far can I see" test, I'm reasonably sure the flash is at high, and clearly brighter than medium.
