Lamps for 3x 17670
Highest possible and safe output bulb for 3 protected 17670 is WA1185
Soon as IMR 17670 become available, brightest bulb will be FM1909
Where do I get an adapter to use the WA1185 in my T-Head and where can I get the 1185?
Thanks
Search CPF B/S/T forum for FiveMega's 5th run of his MN bi pin socket. For bulbs, search the Marketplace for ProofTech's Welch-Allyn bi-pin bulb sale thread.
Are you planning to direct drive this setup, or use a PhD-M6 regulator? The 1185 draws a bit too much power to run in regulation with the PhD-M6. It's also going to be hard on the 17670s, drawing greater than 2C discharge rate.
Varooj - do you have any information on IMR17670 availability? I can only imagine it's something every Surefire owner has been interested in.
Above statement is based on this thread and only a hope.
For now, the only solution is 3 IMR 18650 and FM1909
That's not entirely true. ;) I run 6 x IMR16340 in the stock M6 battery holder with a FM1909 very succefully. That's my WTSHTF light by my front door.
With the load sharing it's only ~2.5Amps on each cell. That ~10 minutes at 5C on a 8C rated cell.
I'm thinking PM12 with 2 A19's and three 17670's in a 3" T-Head.
True, that's doable but charging 6 cells for 10 minutes run time makes it impractical.
That will work to drive an 1185, but the form factor for that light IMO is quite poor. It will be very long, rather skinny, and top heavy. I have a similar, experimental setup with a TLS T5 and one extension tube to run 3x18650.
The 10 min run time is certainly short, but a hobby charger can make quick work of recharging the six cells. It would have comparable run time and identical recharging time as two 16340s in a Pila for something like a SureFire 6P/WA1111, which you've used as an example application for your excellent D26 Sunlight product.
