Laser Clamp Mount Problem-Laser Dimming
sam59
I have a LXGD green laser with a standard clamp mount. When you tightening the clamp only slightly the laser dims and will not work. I can't imagine the clamp is warping the aluminum casing. If you remove the laser from the clamp it works perfect. I replaced the battery and it still did it. Any idea's why this is happening?
Thanks in advance.
Check to make sure the switch is not grounding to the weapon frame. I sounds like when the clamp is tightened, it makes contact through the anodizing and something is shorting out via the clamp / laser / switch.
I agree it's unlikely that the clamp is distorting anything.
How is the switch mounted? Or did you create your own trigger switch? It's possible that the laser barrel is connected to battery positive and the switch is in the negative leg (or vice versa). If the switch is connected to weapon ground, it will not work when everything is married up.
To troubleshoot this, you could try taping the laser barrel with some polyimide (kapton) or mylar tape, this stuff is very thin yet a good insulator. If this material is not readily available to you, use some thin insulating sheet stock between the clamp and laser barrel. If you can clamp it down with the insulator in place and it still works, it was a short and you need to take another look at how the switch is mounted / connected.
Corona,
Thanks for the follow up. I was thinking something along those lines but have not pulled the unit apart yet. Its one of the common green laser you can get off Ebay, it uses the non floating head design with external turret x/y axis adjustments. I have not had this problem with the other floating head design so I need to take it apart and see whats going on.
Thanks Steve
