unterhausen
- Joined
- Jan 16, 2009
- Messages
- 275
My limited tool buying funds are tied up in paypal. So I was on ebay for 3 hours last night and ended up with this.
When I regain my strength, I'm going to buy some boring bars and threading/grooving tools. Oh, and some inserts.
Right hand holders do see a lot of use, as many turning operations are done with the cutter advancing toward the head stock. But a left hand holder is also useful. It allows feeding the tool toward the tail stock, and it also allows facing toward the center of the part. A right hand holder will only face from the center toward the outside, which is not possible on solid stock.The right handed version would be what you use 95%+ of the time when doing turning and facing operations.
....A right hand holder will only face from the center toward the outside, which is not possible on solid stock.
Exactly how I set mine up.To do this, the tool shank should be set perpendicular to the axis of the spindle.
I guess there are more than 1 way to skin a cat, since for 3-4 years I have "only" done facing with right hand tools, and always from the outside towards the center - never from from the center towards the outsideA right hand holder will only face from the center toward the outside, which is not possible on solid stock.
Yeah, I'm not done shopping, just wored out. I have found that left hand tooling is useful sometimes, I just can't remember those times right nowThat particular cutter is a left handed cutter, which although useful to have in a lathe, is not as useful as the right handed version.
Will
The most obvious difference between those two toolholders is that the 16 means it has a 1" shank (16/16), and the 12 means it has a 3/4" shank (12/16). The N means negative rake and the R means right hand.Just when I thought I had a clue....not.
So I'm looking on ebay for the same reasons as Unterhausen.
Because of the advice here I know what kind of inserts I want to use. But the insert toolholders themselves have different designations, whatever you want to call them. 2 insert holders will take the same insert like MCLNR 16-4D or MCLNR 12-4B. What's the difference? Is there a chart somewhere, or better yet a simple explanation?
Mike
This is really important, since the BXA holders only go to 5/8". So the closer to 5/8", the less metal you have to mill/cut to make the holder fit...the 16 means it has a 1" shank (16/16), and the 12 means it has a 3/4" shank (12/16)...
Man, I can't wait for my SINO DRO to arrive. Too bad it will be some time in NovemberMy DRO on the mill, for instance, will calculate the proper spots to drill when drilling holes in a circle. It will also figure out how far apart holes need to be when evenly placed along a line, even if that line is not aligned with an edge. It's a great tool to have.
Daniel
