bootleg2go
- Joined
- Jan 26, 2005
- Messages
- 440
I've modded my glp-110 by doing both the pot adjust and diode/mirror adjust. I also tried shorting the 332 resistor, but that didn't really do anything as far as I can tell. I did get a little boost by increasing the 103(10k) resistor above the pot to 20k. I've managed to get quite a decent increase in output as measured using the led DVM method. It shows the ouput to be about 25-27mw. Another glp-100 a friend bought, I modded the same way, but only can manage about 10mw...not bad as I've doubled the output.
The only problem is that on both units, after 10-15 seconds of continuous use, the output starts dropping on each on. The 10mw unit will drop to 5-6mw and the 25mw unit will drop to around 10-12mw. In each case the output drops by 50% or more. Does anyone have any idea what I can do to get them more stable over the course of 1-2 minutes of use? Does everyone who has modded their 110 have this same output drop as they start to warm up? To tell the truth, I'm not even sure they are really getting hot at all as it is a very short time and it doesn't feel warm at all to the touch. One more piece of info, both unit draw about 225-230ma of current from the battery.
Jack
Jack
