Leaf extender????
bagman
GB
I've tried a search but come up dry, has there been any talk of a Leaf extender ala A19's for his bodies?
I've got a C-M 2 x 18650 and a C-C 1 x 18650 on order but a A19 type extender for 18mm batteries would be superb especially for the 1 x 18650 bodies.
Pretty please :D
That would be nice.
I had a little trouble using an extender with a leef body. I was trying to use a lighthound A19 HA (I don't think the HA ones are real SF parts). I took it to a local machine shop to have it bored to fit 18xxx cells. But it did not work with my Leef 2x18500. I had to use a spacer similar to post number 25 in this tread.
http://candlepowerforums.com/vb/showthread.php?t=137450
The A19 worked fine with my 9P tube, to bad my 9P only fits 17xxx cells. If you compare the shoulder to tube end on the leef to a real SF you can see the Leef is a little shorter.
In the end I got it to work. However if there was a Leef A19 18xxx that would be 2 less hoops to jump through.
I really like the leefs. I have 3 so far and am looking forward to tailcaps as well.
