Hello All,
Yes another newbie here. I've been reading posts and trying to absorb all the info the best that I can for a good while now. There is so much info and not enough time! Terrific site and good people willing to share so much info! Thanks
To the point now. I bought my first "real" flashlight a few months ago, a Fenix P1D CE Q5. I was using the light in cold weather, about 10 degrees F. When I decided to turn it off, I realized the light wasn't going off, then I realized that the threads were seized up and I was actually unscrewing the head of the light exposing the unprotected LED! And I had no way of turning off the light! In order to prevent from getting totally embarassed and abused from my equipment malfunction I discretely hid the light in my coat pocket until the battery ran out(it was on medium and towards the end of the battery life). I then got a pair of pliers and loosened the threads so I could now "turn it off".
I'm thinking the threads seized up on me from a combination of not properly lubing the threads and the expansion of the mail threads on the head of the light from the heat of the LED and the shrinkage of the aluminum on the female threads from the cold making for a very tight fit...right?.. .wrong?...Yeah, I know none of this would of happened if properly maintained.....
I now realize the importance of properly lubing the threads.
Without bashing me to bad the thing I need advice on is should I use locktite or something else to lock up the threads between the lense and led or just tighten it up and do a proper lube? Sorry but I forget some of the proper terminology ...hopefully you will know what I mean.
Thanks in advance,
Tomab (Tom)
PS. Just ordered a Dereelight CL1H 3 3SD, and Zebralight H30. It'll be like Christmas in April!
Thanks in advance,
Tomab (Tom)
