Leatherman tool adapter case - CR123 batteries
pahl
South Dakota USA
Did you know you can fit four CR123 batteries in the Leatherman tool adapter case?
I was not using it for the tool adapter so I thought I would see how it worked for batteries.
It makes a nice and compact battery case.
Does it make any difference if the adapter is for the Wave or the Supertool ?? If the batteries still fit regardless then this is pretty cool ! Thanks Pahl.
[ QUOTE ]
[/ QUOTE ]
The case I used was for the Supertool tool adapter. I'm not sure if the case for the wave tool adapter is the same size.
I had to remove all the little pegs that were molded into the case to hold the tool adapter and bits before the batteries would fit.
