Sold/Expired Leatherman Wave multi-tool FREE SHIPPING CONUS - SOLD
Status
Not open for further replies.
bladesmith3
Well-known member
colorado springs
this is an almost mint wave. great condition.
1. Needlenose Pliers
2. A cast pinching tool with an angled nose for holding or manipulating materials, ideal for small objects or tight spaces.
3. Regular Pliers
A cast pinching tool for holding or manipulating materials.
4. Hard-wire Cutters
Bypassing cutting blades ideal for cutting hard wire.
5. Wire Cutters
420 HC stainless steel bypass cutting blades, meant for cutting regular-gauge wire.
6. Wire Stripper
A useful notch for safely stripping multiple types of wire.
7. 420HC Knife
A knife crafted from 420HC, a high-carbon stainless steel that is corrosion resistant and can be easily maintained.
8. 420HC Serrated Knife
A toothed blade crafted from 420HC stainless steel. Serrations grab and cut materials easily, making this style of blade exceptionally useful for cutting through rope or fiber.
9. Saw
A toothed tool made from 420HC stainless steel that is designed to work on a pull motion, which requires less effort and has less propensity for breakage. The open-tooth design keeps the saw from filling up with material, allowing the user to complete a job without pausing to clean the tool.
10. Spring-action Scissors
Scissors for cutting paper or other light materials that automatically spring back to the open position when not being used. Sprung tools are helpful for reducing hand-fatigue, especially in scissors where the user may be opening and closing the tool many times to make multiple cuts in a row.
11. Ruler (8 in | 19 cm)
A precise measuring guide for determining length in inches or centimeters, up to 8 inches or 19 centimeters.
12. Can Opener
A lever/punch style tool to assist in opening canned goods, perfect for camping or in survival situations. The blade on this tool has been ground in a way that it pushes the cut metal into the rim, keeping sharp edges from cutting the user as the can is handled.
13. Bottle Opener
A tool that allows the user to pop the top on a favorite beverage.
14. Wood/Metal File
A 420HC stainless steel tool with a crisscross pattern that forms a rough surface for the user to file or smooth both wood and metal surfaces. The file pattern on Leatherman files is extended to the end of the file as well as down the side to give a file stoke and/or a more precise file edge.
15. Diamond-coated File
A stainless steel blank coated with premium synthetic diamond particles which create a rough surface that can be used to sharpen hard steel blades with much more precision than wood/metal files.
16. Large Bit Driver
This driver slot holds any of the full-size Leatherman tool bits in place and allows the user to exchange bits for different jobs. Not intended for the eyeglass screwdriver tip.
17. Small Bit Driver
This small driver slot holds the Leatherman mini tool bit in place and allows the user to use either end of the bit for different jobs. It is not intended for use with full-size screwdriver bits.
18. Medium Screwdriver
List Date: 5/3/2015
For more info, click here to view the original listing: Leatherman Wave multi-tool FREE SHIPPING CONUS
SOLD
candlepowerforums
Status
