Hi. I'm completely new to the forum and new to LED's and electronics at all save the last week and a half when i decided that i wanted to install some led brake lights/turn signals into the saddlebags of my motorcycle. I looked at automotive stores and online but found nothing that seemed like it would work so i did research on how to make an led array. The internet is a great resource and i've got it all done now but i ran into a problem, not all of the blinkers in my array come on. So you know, its a 2x5 inch board, 96 leds per board. The blinker side of them is 32 yellow leds, arranges in series of 6 then connected in parallel with an 82 ohm resistor (one series is 3 leds with a 220 ohm resistor). When i wire them in with my existing blinkers, only 5 leds total come on, and not in the same series. I know that they all work, because when i connect them to the brake lines, all are on and bright. Any idea why they arent working with the blinker lines and how to fix it?
