Walterk
Naturally, thinking of going Led. Although I understand most parts of Led, I can not make up my mind and choose what to use.
So, any advice and experiences welcomed !
Especially links to products that proved to be adequate from real life experience are much appreciated. (There is a lot to buy, but hate to buy 9x wrong and to find the 10-th to be almost what I look for.)
I have 10 x 20 Watt Halogen downlights, on 3 switches, powered by DC converter/24-27v batterys, parallel with different cable-length up to 8 metre with 18awg/1,5mm2 crossection. Two string have PWM-dimmers (means regulation on voltage I think ?) on them. I am hesitant to alter the wiring, but I could put a variable current regulator in place of the pwm-dimmers.
The existing G4-fixtures are rear-pins with frosted glass window. They are well ventilated.
The to-be colour-temperature should be bulb-like. (3200-4000? )
Options:
- build a Led-replacement, not preffered, capable when good solution is at resourced, not interested in endless experimenting.
- find a suitable G4 Led-replacement, valued-by-experience products appreciated.
- replace fixtures with non-G4 and use Led-replacements that have good credits.
Please help ! :wave:
Edit: Info on why it is difficult to find led-replacements http://boingboing.net/2009/10/23/leds-throwing.html
Options:
