rolfknudsen
Hello
New here and greatly appreciate any input on the following:
I have a table lamp design which has a 700 mA LED. This is driven by a 12v wall power supply and need an inline dimmer switch.
At the moment I can source a 350mA dimmer switch, but would like a 700mA.
Is there a small module I can house in the lamp after the dimmer switch, before the LED so I can have a 12V dimmer switch on the cable, going to this module that then puts out more or less current so the LED lamp is dimmed?
Or am I going about it in the wrong way?
Ideally I would only like max 12-24V from the wall power supply, so I do not have the risks of mains power design in the lamp itself. I am NOT an electronics engineer, but a designer.
Thank you!
Thank you!
