Hello, hopefully I am posting this in the right section, if not my apologies. I am hoping someone can help me, I would like to install a half dozen LED landscape lights on the posts at the gate of our property as well as a couple of LED floodlights, one on either side of the entrance to illuminate two 25' flagpoles I plan to install. The concern I have is that the entrance is roughly 1000 feet from the nearest available power source (our house). I know that running 120V's that distance would require a very low gauge wire and would be very expensive, I have also considered solar powered LED's but would like to leave that as a last resort having had issue with some in the past. Is it possible to run LED's with that distance between the power source and the LED's using low voltage, less expensive wire? If so any suggestions on gauge of wire needed and what I should consider when purchasing lights? Also if possible would I have to use a higher voltage transformer at the power source than the one typically supplied with landscape lights due to the distance? Any help would be greatly appreciated. Thanks!
