LED LENSER
johnhunt
HI all new to this i have a led lenser flashlight that takes 3 AAA in a plastic body
just like to know if ther was a biger battery i could get instead of the 3AAA
thank you
I am not sure I understand your question. 10440s are about the same size but peak out at 4.2v and that would be a big no no for a light like that.
With that light you can't run anything other than the 3AAA's it's built to run in it's battery carrier. The best you can do is run energizer lithium primaries.
There is a lithium-ion battery that is around the same size as would fill the battery compartment in a 3AAA light, and the voltage would be around the same. However, as stated above, battery holders of the type use by LED Lenser often have both the positive and negative contacts at the head end of the battery holder, whereas the li-ion cell will have the positive contact at the head end, and the negative contact at the tail end. If this is the case with your own battery holder, then the li-ion cell wouldn't work - certainly without modifying the light in any case.
