Help Support Candle Power Flashlight Forum
that certainly right in terms of the few new versions ones I've seen beamshoots of. Those ones were not as tightly focussed as my old version was even before I "tuned" it.but the focus doesn't seem to be as tight as with the old versions.
The M14 doesn't get very hot with prolonged use (tried running it for 30 min) at least not with NiMH. NiMH doesn't heat very much at 1 amp so a great part of the heat is coming from the LED. And the size of the M14 body means a large area for dissipation. And the black color helps too (yes that's true!).
not getting hot is an excellent sign that there is a poor thermal path between the emitter and exterior.
Thanks for posting the images McAllan. It is nice to see LED Lenser including regulation in their new lights. I hope that they do the same with all their older models, starting with the X21, the one that really needs it.
Speaking of batteries, does LED Lenser still only recommend the use of alkaline cells exclusively as in the past or has that changed with the new M14?
and please check your thermodynamics for a led on a small pedestal.
how about objective observations instead of blind fanboyism?It's no worse than all those tiny waffers. And still it does not change a thing.
Look at this post for a P7. It's about 1 cm or less. Absolute no problem to dissipate 3 w sufficiently. PERIOD
Of course there'll be a little more thermic resistance compared if it was flat against the larger area but that should not translate to any increase in temperature which should be alarming by any means.
Fair enough if you don't like the light. But please either just say that or come with some real critics instead of trolling.
the heat flux of their pedestal design is approximately 50% worse than a conventional heatsink design. alternatively, a conventional design is 100% more effective.
try measuring the temp of the led itself after having been ran for a while in LL's little oven.
hint: it can easily reach >=130°F
And you did measure it? No of course you haven't :thumbsdow
