McAllan
Re: Led Lensers - Picture of M14 driver
Can't speak of that. Only the M14 😉
Unfortunately the plastics is secured with some torx screws and I don't have a torx that small so we can't take a look at what's under there yet.
138 F sounds a little on the high side. With a junction to solder side thermal path of 8 C/W according to data sheet that translates to a junction temperature of ~180 F. But as said earlier the 3 w heat dissipation is on the high side. Could be interesting to know it more exact for and XR-E run at 1 A (or perhaps I've just not read enough in the data sheet). And then there's also the issue of we don't know how much hotter the over side of the LED is compared to the under side. One thing for sure is that if temperature is different then it's hotter in a non ventilated area as there's not a heat sink at that side.
So yes it sound a bit on the high side. But still well within allowable limits according to data sheet as I see it.
i have personally measured 138°F on the T7![]()
