<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by ChrisM:
I was wondering if someone could explain this to me in newbie LED terms (since I've never done a mod and would like to do a minimag-to-LED mod:
Anyone have any suggestions for me on doing my first minimag to LED mod?<HR></BLOCKQUOTE>
ChrisM,
To do the simplest Minimag-AA-to-LED mod, you'll need:
- 3x 'N' cells (each is 1.5V, LEDs run happily on 3.6 volts or thereabout, so this will be overdriving it a bit)
- 1 nichia 5mm or 3mm LED (color of your choice - most of us here like white). If you can get them, the best white 5mm nichia LEDs have this part no. NSPW500BS. If you're feeling adventurous, try out the 3mm part, which I *think* is NSPW310. The trailing B and S in the 5mm part no. refers to the color and brightness ranking. Not sure if they have the same nomenclature for the 3mms though.)
- 1 spacer (can be made of foil, a bolt/screw, a spring - almost anything electrically conductive)
To do this mod:
- Remove the old bi-pin bulb from the Mag.
- Put 2 AA batteries in the light first for testing.
- Take a 3mm/5mm LED and snip off the excess lead so that the legs are about the same length as that of the original Maglight bi-pin.
- Stick the LED legs into the bi-pin socket, never mind polarity for now - that's why the 2AAs are there. If the LED lights up - great! That means polarity is correct. If no light emerges, try wiggling it a little, and if still no light comes forth, switch the pins around. Once you've found the correct orientation, try to find a way to make a note of it.
- Now that polarity has been found, replace the 2AAs with 3Ns. The 3Ns are quite a bit shorter than 2AAs, that's why you'll need a spacer. Experiment around with foil first before settling on a final spacer.
- Assuming the light portion is now working, if you are using a 5mm LED, you'll need to bore out the bulb hole of the minimag's reflector to fit a 5mm. If you chose the 3mm LED, there's no need for this (hurray!). Just use a good pointy knifeblade or scissors to scrape away the excess material until the 5mm LED just fits.
- You're done! If you have xtra LEDs around, try grinding down the LED lens to almost the die and you might even have some ability to focus the beam!
Good Luck - hope this helps!
