LED Matrix display in daylight
FlipFlop
You can ask Lite-On:
"Please contact us for LED products technical support and RoHS survey support.
Main Office
720 South Hillview Drive
Milpitas, CA 95035
Tel: 408.946.4873
Texas
1817 W Braker Lane, Suite 100
Austin, TX 78758
Tel: 512.691.3343 or 512.691.3348 "
regards,
Steve K.
edit: looking at the datasheet, it appears that the recommended current is 25mA. Seems very unlikely that this would be visible in daylight.
Basically what is the mcd that required for LEDs display to be seen in daylight?
I think it's not going to have so much to do with the brightness, but how it is set up. If each LED has a small "shroud", I think it will make it more visible since it will cut out ambient light and make the actual LED more visible.
having the leds set against a black background does make a difference, at least for the traffic lights that I see. I can't imagine they would show up so well if it weren't for the high contrast of the black face of the traffic light fixture.
I've got some 5mm red leds that I use in a bicycle taillight. They were pretty leading edge stuff when I bought them 6 or 7 years ago. Don't recall the mcd rating, but I want to say they were at least a few thousand mcd. They are visible in the daylight, but not bright. I'd suggest either buying a few different leds and try them out, or do some searches for daylight visible leds and see what pops up.
There's also the issue of viewing angle; i.e. how far off of the main axis do you want this to be visible? The wider the viewing angle, the more power you'll need. ...or conversely, for a given power, the wider the viewing angle, the lower the intensity (as measured in mcd).
regards,
Steve K.
Thank you for your answers/
but I need to know what is the recommended mcd for LED in daylight???, for searching another display
