12-29-00 LED bulb from Ledcorp. If you have a 3 cell mag (C or D) and want to turn it in to the ultimate backup flashlight here is the item to do it! This is extremely bright and unconditionally warranted by LED Corp. The lamp was pulling 65ma on 3 new C cells. One of the nice things about this LED is that it doesn't have a pre-focus like most LED's. In other words it emits light in every direction so it is great for using in existing 3 cell lights. This lamp also comes in a resistored down version for 4 cell lights. To sum up I would really recommend getting a 3 C cell Mag and this lamp, you won't regret it. This also gives you have the option of using the LED or the existing lamp (carried in tail cap) for a bright or normal light output. Using 3 C cells this light should run bright for about 4 days or over week of useable light, using 3 D cells you should get about 10 days of bright light and almost 3 weeks of useable light!
I am a newbie with all these fancy-schmancy terms
I see MCD used as output and MA used for draw (no?). I am curious about these lamps and would like to know what these are comprable to in terms of output power. I can accept "bright as a photon", or anything else like that.
Also, I have no idea how I stumbled across your wonderful forum. Really. Must be the law of random keypresses. Honest!
