OK! More details on Aragorn's 2 Quest 123a Rechargables.
Voltage 2.9 and 2.89 volts fully charged.
mAh not given anywhere, but someone good at math might be able to figure it out based on the numbers below and the wattage of the lamps tested.
E2 runtime test
minutes - Lux at beam center
00 - 1150
04 - 921
10 - 771
11 - 400 *losing it...
12 - 100 *pretty much dead
So about a 10 minute runtime at good light.
Since a normal set of 123a last 90 minutes in an E2, and these lasted about 10-12 minutes, the mAh should logically be about 1/8 to 1/9 that of the mAh in a normal 123a (does this make sense or am I way off?)
P61 runtime test was very quick - start at 5500 lux at beam center, "brown down" at 3 1/2 minutes, dead at 4 min.
Now these tests were done with "constant on". Momentary flashing type use may last longer.
BTW, a close look at the diameter of the batts shows that there is about a 1 mm thick layer of cardboard wrapped around the outside of the battery with the Quest label on it - effectively expanding the diameter of the battery. Under the cardboard a green plastic coated rechargable battery can be seen, but we didn't want to remove the cardboard for fear of ruining the battery. So it looks like this is actually a slightly smaller rechargable battery which has had it's diameter expanded so that it works in 123a applications.
The Quest charger had the batteries fully recharged in less than 40 minutes.
On a side note, when testing the P61 module runtime, it was installed in a Legend LX. The lens became warm after 4 minutes, but you could hold your finger on it and withstand the heat, so it didn't get too hot. There were no signs of meltdown. Oddly enough, a little bit of condensation formed on the inside of the lens as it cooled, but it evaporated instantly when we opened the light. The metal head and the body of the light became very warm, so the heat seems to conduct down the springs behind the reflector and into the body and the batteries.
On a cool note, at 2 inches we were able to get one of those science store "hand boilers" to bubble after about 10 seconds of shining the beam on the base
- pretty cool!
