L
LED1982
- Joined
- Jan 26, 2017
- Messages
- 98
Re: http://www.worldpartners.co.th/LM70Super.html
Dan, if I buy a Superpower how much would you charge for this upgrade? And if I got your upgrade in it would it be 100% on par with the XeVision XV-LX70's durability and quality, and would it then have all the advantages that XeVision has over Lemax? And is there an option to get the soft diffuser, and the yellow fog filter for the Superpower like you can get with the XeVision XV-LX70? Thanks Dan
We (XeVision) make all of the ballasts (light engines) for the LX50 and 70 and 70 Superpower as well as Lemax weapon light models, those assembled by XeVision (XeRay) and by Lemax.
Also, we provided the USA made electroformed reflector choice and manufacturer on all of the LX50's, LX70's, Superpowers and weapon lights worldwide.
Lemax uses a 35 watt rated D1S bulb on all of their Czech assembled units LX50, LX70, the Superpower and weapon lights. Bulb replacement in that case, is mostly not recommended to be done by the user and requires some std tools, additionally one being a metric hex wrench. Also, the Lemax D1S bulb may need to be re-shimmed to adjust for very small variations in the igniter dimensions, to maintain precise bulb positioning (focus), as done during initial assembly.
XeVision uses a much more expensive, higher wattage rated bulb than Lemax on the 50/70 watt XV-LX70 XeRay, also not the same bulb as we use in the 35/50 watt XV-LX50 XeRay. In both cases, our bulb replacement is very easy, only taking a couple of minutes (2 or less), because we use our Proprietary XeSparQ igniter/socket which the bulb plugs into (a 2 part assby including the bulb, fully replacing D1S), making bulb replacement fast and easy and a relatively low skill operation, easily done quickly in the field and doable in emergency or tactical situations, requiring no tools of any kind. The bulb focus is not affected in any way, when only the bulb is being changed and the igniter is not being replaced, as with the D1S mentioned above.
The benefits of a 50+ watts rated bulb, are much longer life and very much better lumens maintenance over the bulb life.
For premium grade products, it was always our feeling that premium bulb selections were also the proper choice in ALL cases.
We could even do the upgrade on your Superpower.
You would have the only Superpower in the world currently (likely ever) with the upgraded bulb and igniter. You could keep the stock bulb/igniter as spares.
Dan - XeVision
