I like that someone is folllowing the mod a light that meets the German StVZO standards.
Someone in this thread, I think it may have been
panicmechanic suggested the Phillips light as just begging for an LED upgrade, and it was less expensive than some other choices (circa $100).
My concern about the beam pattern of these lights stems from experience with a road beam experiment (ongoing, most recent post this page).
It is admirable that engineers harnessed the light of 3 watt generators putting as much of the light as possible where it would help a rider see. This holds true whether it is 3-4 watt halogens or early generation LEDs. So what concern do I have? It stems from being seen. This may be a function of whether you have bike lanes, a bike savvy motoring public, and an expectation by motorists that bikes are in the trafffic mix. I have none of these.
A video of my lights in the day with a snoot on the low beam to tame its medium wide beam, and the helmet light with its very narrow 8-11 degree full cut off beams showed that they were not showing up for a video camera at driver height in the oncoming lane unless I aimed the helmet light at the driver/camera. The night video was a bit better. Too many driver's did not see me or thought me a slow bicycle. Recent
day and
night video with the bar light unleashed from the snoot show it might be a bit too uncivilized in night use. Drivers wait till I ride by when they don't need to. This may be a good thing. I have had some moderate indications of dislike but no one gave me their high beams. I will do a drive by myself tonight to assess whether they have a beef or are just wimps. At 50% power the low is about as bright as a Magicshine and maybe a bit narrower but not by much. On full, it is close to 1.5 MJ-808's output.
Pe2er had a post in a thread here somewhere of his new Strada HPV which uses a StVZO standard main light and has fill led lights to add more spill or 'be seen ' light. It appears the concern about being seen with these lights has some support. My helmet light can be aimed in only one direction aat a time so it is not the answer to the problem when cars come from both sides. My high aimed at the driver has stopped at least three hooks that were beginning, though.
So, I pose it as a question: is the German StVZO liight standard a bit too effective and does it reduce a cyclist's visibility to motorists, especially in traffic situations where motorists rarely see cyclcists, so may need a bit more? If so, it would free your modding works some if you lived in a country where the standards do not apply. I may be a good thing if your resulting pattern is a bit broader. A thought.
Meanwhile I will see if I have an issue with the unfettered low beam that needs attention, or not. If it is uncomfortable but not blinding, that may be a very 'safe for me' setting. Just so long as a car full of really big angry weight lifters doesn't u-turn then overtake me to 'larn me a lesson' about using bright lights.
