It looked like my response to znomit did not load. If it did and this doubles up, the admin can delete it if I can't remove it in edit mode.
Znomit made an excellent point that even IF (a big if) an optic from a 3-watt halogen would work, it has likely has little future production.
A previous thread on 'How Much is too Much' light for the road had those who supported a scorched earth approach: More is better. :thumbsup:
In my expereince: not always.
Using an HID on the road has hammered home the lumens versus beam issue. My neighbors complained, so most of the HID was aimed off-road to the right. There is little pedestrain traffic in the early morning or later at night, so that did not cause a second issue, unlike it might in say, NYC. I did not get the light where I wanted it.
One pickup driver was nearly blinded by the light (sounds like a hit song to me) when he ran a stop sign and turned left in front of me at around 6:00 AM. 500 lumens of HID shone full on his face through his driver's side window at maybe 10 feet away. I didn't feel very sorry for him with all that adenalin coursing through my system at the time. :devil:
To be fair, he probably had never met another vehicle at that time and place, let alone a bike, may have been half asleep :tired:, but obviously was not prepared to yield to cross traffic, and no Boy Scout. So a good bright light helps, but it's no safety talisman.
The HID is gone and too expensive for its output to replace. I have a cobbled light giving me 80-100 lumens which is a bit more than a 'be seen' amount on dry pavement, and not enough with wet pavement.
So I have the need for more light, built some electronics kits, and lots of DIY experience, (mostly good), and a desire to experiment tempered by availability of funds.
A poster on the 'Too much' thread suggested there are multi LED solutions to the road high-low beam issue. I take it that these would be one or both, of either: a spot aimed low and right and a narrow beam aimed high and straight ahead (mostly) or a Hi-Lo current setting, as in the Taskled software. Any other solutions? Just reaim the light up/down?
So I searched CPF but did not find answers to:
1. Road experience with a current driven Taskled enabled Hi-Lo beam with one or various lights (beams shots yes, real world riding, no.
How well does this work in traffic? Any beam width issues?
2. Ditto for multi-light LED units. Although 10/20watt and 15/35 watt etc. dual light spot-narrow beam halogen systems have been around, their lack of lumens compared to new LED's makes those reviews irrelevant IMHO.
So how well do higher lumen dual/twin systems work as high/low beams?
(A lot of personal preferences are involved here, I know, but I think I can glean what I need.)
3. I am saving for a Schmidt wheel. Batteries can be incovenient. However, with only 3 watts, the lumens and distribution issues are critical. So using one, or at most two, LEDs ALL the time regardless of beam shape would be nice. Multi die LED's and focusing issues are an interesting problem within this larger low watts issue.
The CREE XP-G R5 will put 250-300 lumens on the road at 3.3 watts (1 A, 3.3 Ohms), depending on lens/reflector losses, how warm it gets, and losses in the rectifier and other circuits. The S2 should be 5-10% higher again.
I understand that 300 lumens was once thought adequate for night mountain biking. At 0.5 A output from a generator, the R5 is only 3.15 ohms, or 1.6 watts and puts out 140-200 lumens depending. So two at 500 are in the 280-400 lumen range. Moore's law says that in a couple of years we could see another 50% improvement on this.
So why do we want to mess around with hard-to-focus multi die LEDs? :shrug:
In the mean time, I need more light to ride, and to use as a benchmark for experimentation for my future generator system. I have about $100 or so, and a battery with chargers in hand.
I am thinking either 3 or 5 XP-G R5's to use a 12 volt 50 Watt-hr battery pack I have. Using the Bflex for three, or the Maxflex for five LEDs. (Four XP-G's puts me at a Vf of 12.3 at 300 mA to 13.2 Vf at 1 A and out of regulation with either driver). Running either system at lower amps will be more efficient, provide a lot of light, but permit much longer run times than the HID on the same battery. Runtime is important as the battery ages and loses capacity. Headroom to higher current will let me ignite the road, if I must. :devil:
Sorry this is long. I have read a lot of CPF and experience says to hone the design at least three times before ordering parts, measure twice and cut once.
Thoughts, anyone?
