Glock27
Battery University recommends a charge rate between .3 to .7c.
I mostly charge Panasonic 18650 3100 and 3400 mAh batteries.
Does charging at the higher .7c rate have a large effect on cell life?
If Pila IBC outputs ~600mAh that would only be ~.2c.
I bought an Xtar SP2 which is capable of a 2000 mAh charge rate.
Should I stick to the 1 amp setting or pump the max rate?
B27
B27
