the current sure goes away in an unregulated type of thing as soon as the batteries should be pulled.
so if your running a load on them, and the output drops be it even just one cell in the packs current dropping, then stop the load quickly.
possible stupid ways to automate it (other than protection).
how about a photoresister in the light /ubbthreads/images/graemlins/smile.gif when the photoresister isnt being pulverized, then the load should stop. that could be partly calibrated.
and that is basically what the user should do quickly after it happens.
Leds in Direct drive, are so sensitive , compared to incadescents, when the voltage/current drops its pretty visable, even if its when it goes from 3.5 - 2.7
a WHITE wont even trigger the gate at a lower voltage.
(so it basically goes OFF by itself in dd)
BUT
in the concideration of that, the current is so low before the gate non-trigger, the battery is certannly completly drained before it does stop. and after a rest it can be fired up again.
Once you go to PACKS in series, and DC-DC or boost or unboost curcuits all that CHANGES 100%
so parellel 1-1 white led & Li-Ion cell is pure dummy stuff almost, perfect for a dummy like me
