SteveTheReaper
- Joined
- Dec 8, 2006
- Messages
- 15
I bought these D size LiFePO4 cells and this charger. I shrink wrapped the cells together into a 4 cell stick pack and put them on the charger. They were apparently almost fully charged already, as the light on the charger turned green after a couple minutes.
I put the pack in my HID Mag and ran it for a while. After that, I put the pack on the charger and left it for a while. When I took it off the charger, I found the pack had 0 voltage.
I took apart the pack, and found that the two end cells have 0 voltage, but the two middle cells each have 3.3 volts.
The first thing I suspect is the charger, because I looked on batteryspace.com and saw that the LiFePO4 charger they sold me appears to be the same as this lead acid charger. The charger I have even has the 6V/12V switch covered with a sticker.
I also used a rather powerful magnet on the negative end of the pack to hold the alligator clip on. Could the magnet have caused the problem? Is it the charger? Did I just get defective cells? Does anyone know what the problem is?
