LiFePO4 batteries
I bought a pair of AW's and a charger to play with. I charged them up and got around 35 minutes of runtime on a Wolf-Eyes Sniper with HO Cree. It doesn't seem like much, but in real life usage I can go three or four days between charges. Although I feel pretty comfortable using protected [SIZE=-1]Li-ion I [/SIZE]like the peace of mind in charging and using these cells. According to what I've read they will not vent or explode. See AW's sales thread here for more info.
The kaidomain cells seem good.
I'd like to get some to experiment, but the lower voltage is a problem for devices expecting normal LiIon cells.
On the other hand, gadgets that use two AAs in series could be rewired to use two LiFe 14500s in parallel...
INQUIRY:
I too noticed the KaiD lipo **14500** I'm interested in buying a few.
https://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=2868
My first questions is. Can the Ultrafire/Darin wf-139 charger charge these 3vdc lipo's? Safely.
I've heard rumors that a special charger is needed. Unfortunately there is little data (white papers) on the charging requirements of li-pos.
I use currently 14500 li-ions (3.7vDC) 1Xli-ion + a dummy battery with a resistance in an ex: ultrafire-606A FL and it's wonderous.
My main question about the LI-POs is if they would give any better runtime (1li-po cell) over a 2xAA nimh @ 2000mah each setup (averaged out common ni-mh)?
Last question: Would it be safe to run a single 14500 LI-PO in a single AA FL?
Thanks.
So could you safely run these in Incan lights like a SF 6P with stock bulbs and not instaflash them or reduce the life of the bulb? If so this will be a great rechargeable solution for "stock" lights.
Hi.
Based on the limited specs on lipos (why does that sound like a medical procedure ;) Heh, they sucked (liposuc...) the extra fat out of the li-ion to make a li-po... OK you can groan now :) .
LI-POs have a lower discharge rate. However they have a very smooth and safe flow rate. This is why sony and others are switching thier li-ion's for li-po (after that li-ion distaster Sony underwent).
I would be concerned if you used 14500-18670 "li-ions" in your sf-6p without some form of resistance.
I've ordered a few of the li-po 14500's . From the tech specs i should no longer need a resistance in my 2xAA FL, that was needed when li-ions were used.
Thanks
:confused: Do you mean LiFePOs? (With or without the 4.) Your mention of safety implies yes. So do you mean a lower self discharge rate? LiFePOs have a higher discharge rate. Wikipedia:
LiFePO4 cells have higher discharge current, do not explode under extreme conditions and weigh less, but have lower voltage and energy density than normal Li-ion cells.
I don't see any chargers for these batteries on the Kai site so you're probably going to have to use magnets & wires with the 3v 123 chargers.
If you live in Australia you can get them cheap here found them while doing a search. It looks like they put the real capacity on them, not an exaggerated one!
These things would be awesome for a bike light battery pack, it would be great if somebody made 18650 battery holders for such applications!
According to the specs the manf provided the 14500 li-po kai sells are identicle to AA alkalines in form. Therefore no magnets required.
I'l provide a review when my order comes in.
So what can you use to charge these batteries?
Also, are these batteries shorter than Li-Ion 14500s? The AW 14500 that I have seems a touch longer than my Eneloops so my L1D can't go into turbo mode when the 14500 is in there.
Thanks.
To stress what TorchBoy said:
LiFePOs are not the same as Li-Po!
Moreover, LiFePO batteries have a nominal voltage of 3.2v, quite a bit lower than Li-Ion's 3.7v. You can't charge a LiFePO in a Li-ion charger (there is one RCR123 charger that has a 3v switch and can be used for 123-size cells, otherwise you're the world of exotic RC chargers).
Expect to get half of the Li-ion capacity in a LiFePO of the same size.
Do LiFePO4 batteries need to be protected from overcharging and deep discharging? If so, are they available as protected cells? I've only seen what I think are unprotected ones.
I've read that they are resistant to overcharging, but I haven't seen a reference to the possible dangers of over discharging.
Can LiFePO4 cells be used in series without protection circuits (like nimh), or do they need to be protected like normal Li-ion packs?
-Joel
I have received 3 sets from Kai today. I ran the first set without first charge, It measured 3.33V on my multimeter. In my A2, it lasted 20min on incan and start flashing. I took it off and check the voltage. It reads 2.8V and kai mentioned that it is safe to discharge to 2V. I am in a process of charging up the first set and ran Gladius on the 2nd set.
Edited
It lasted 40min on the Gladius and the end voltage read 2.7V.
I don't think the LiFePO4's have any undercurrent protection so it's not obvious to me why the lights cut out - do these lights cut out with Li-ion too?
Which size cells are these, and how are you charging them? I order a pair of 18650 LiFePO4 and am wondering how to verify they really are LiFePO4 and not low-capacity unprotected Li-ion. I intend to charge them with a Triton.
PS. Oops - I don't think Triton has a LiFePO4 program
