LiFePo4 Over discharge
LiteShow
Winnipeg
Somehow my P1DCE Q5 wasn't turned off properly and it was left on in my pocket until it completely drained the RCR123A LiFePo4 battery. It could have been on for as much as a couple of hours or even as long as 18 hours over discharged.
Anyways, because of the safe chemistry, no gases were released and no mini explosions occured. The first things that came to my mind was that I killed the battery. I quickly checked with a voltmeter and the open voltage was like 0.7 volts!! However, the voltage was very slowly climbing back up. So I waited like 2 hours and I was still only getting like 1.5 volts. The smart charger refused to charge it because the voltage was too low. So I put it across the terminals of a another charger - a NIMH charger for like 5 seconds and the voltage across the battery shot up to like 1.9 volts or higher. The voltage was then high enough and the smart charger was able to fully charge the battery - back to 3.31 volts.
I am sure I shorten the lift of this battery, but am very pleased that I could still bring it back to life. Most importantly, the safe chemistry did not vent any gases in the abuse.
i had the same experience
i probably shortens the lifespan of the battery but it seems save.
Li-ion however also recovers from overdischarging (voltage will climb back up) BUT THESE BATTERIES WILL BE PERMANENTLY DAMAGED.
i damaged a couple but i am still a bit scared to see what happens when i try to recharge them.
An overdischarged LiIon will lose capacity and its self-discharge will increase. LiFes are usually far more tolerant of abuse, so it's likely you haven't damaged it much.
It is hard to know how much you damaged it, but the damage is proportional to the time it spent at the extremely low voltage.
