Light Review: Fenix BC30R Bicycle light with OLED Display
subwoofer
Hove, UK
Winner of several awards on its release in 2015, the BC30R from Fenix continues to impress. The first light from Fenix to incorporate an OLED digital display, I'm hoping it won't be the last, as this feature makes a great product outstanding.
I'm going to be taking a closer look and making comparisons to the previously reviewed BC30.
Taking a more detailed look:
As with the other Fenix Bike lights I've had, the BC30R arrives in a presentation box.
The light unit and accessories are held in shaped cutouts in the foam liner.
Included with the BC30R is a quick-release mount with rubber spacers (for different size handlebars), a remote switch for Burst mode, a USB charging cable and the instructions.
The burst switch has a micro-USB plug to connect to the BC30R, and a Velcro strap for fitting to the handlebar. The button has the Fenix logo moulded into it, but this has proven virtually undetectable in the photographs.
Looking even closer, you can still not really make out the Fenix logo. The switch material is a GITD rubber.
A well made micro-USB cable is included and is branded as Fenix.
The mount is very sturdy and easy to use. In this photograph the top of the mount has been angled to show the adjustment available to the user.
MyFenix have Laser engraved the Tactical Reviews logo onto the upper casing (plastic) and the lower casing (aluminium) giving two very different finishes.
On the metal casing the engraving has taken off the paint to show a slightly golden-brown metal surface.
On the plastic casing the engraving looks quite different. Both engraving effects are very appealing.
On the top of the BC30R are the three control buttons and the OLED display.
Flipping it over there is the quick-release mounting rail and the USB port cover.
Lifting up the cover reveals the micro-USB port.
The BC30R slides onto the mount from the front, locking into place. The tab at the rear of the BC30R is pushed down to release the unit and allow it to slide forwards.
Two XM-L2 LEDs are used with specially designed optics the produce a reduced glare beam (reduced glare for oncoming traffic).
The top section of the optic is responsible for directing light that would otherwise be wasted upwards (and cause glare to other people) down onto the ground where it is useful.
To charge, simply connect up the USB cable. The BC30R will charge from any suitable USB port/charger with only the charge time varying. I did not measure more than 1.2A draw across various high power chargers.
During charging the buttons are lit green, and the OLED display shows the approximate charge level.
There is an almost direct comparison with another Fenix model, the BC30. The BC30 is a simpler version without the OLED display, but with user-changeable cells. Then next three photographs show how they compare in size.
If you look dead on from the front (lower than the view in this photo) you would be pushed to tell the difference as the bezel, optics and LEDs are the same.
With its changeable cells, the BC30 has a lever to open the battery compartment on the back.
The beam
Fenix have concentrated on what makes a real difference to riders. Neutral white emitters are used to help with colour recognition and making the rider's view clearer. The effects of the optic are not that obvious in this scenario.
Taking Tactical Review's standard outdoor shot...
For the full set of beam-shots, please go to the Exclusive Content at Tactical Reviews, but remember to return to this forum to discuss the review.
Modes and User Interface:
A significant differentiator for the BC30R is its OLED display which becomes an outstanding feature of the user interface.
There are three buttons which are used to control the output, the main power switch and a '+' and '-' button to go up and down output levels. Also included is a remote switch button which only controls the Burst mode.
You can choose from Burst (using remote switch), High, Medium, Low and Eco plus a flashing mode.
To check the current state of charge of the battery, from OFF, briefly press the power switch and a battery symbol will be displayed on the OLED screen. In this case the cell is between 50% and 75% charged. During charging this charge indicator is also shown.
To switch onto Burst, from OFF or ON any mode, press the remote switch.
From OFF press and hold the power button for 1s to turn ON to the last used steady mode.
When ON use the '+' and '-' buttons to increase or reduce the output. Once you reach the lowest output pressing the '-' button again does nothing, and the same is true when going the other way.
During normal use, the OLED display on the BC30R will show the remaining runtime (an excellent feature) for that mode. When you turn the BC30R ON, its display initially shows the level and the 'hours' part of the remaining runtime and then it calculates the 'minute' part. Here the remaining runtime for the level 7h50m. If you change mode, this is recalculated and an updated value displayed.
The reason the numbers look dim is due to the display using a raster effect. The shutter speed used has not captured the full display at maximum brightness. To the eye it looks clear and bright.
For flashing mode, from ON, double-click the power button. A lightning bolt is shown flashing on the OLED display and no runtime is shown. To exit flashing mode press the power button once.
To switch OFF, press and hold the power button for 1s.
Batteries and output:
The runs on a built in battery pack.
For Detailed output measurements, please go to the Exclusive Content at Tactical Reviews, but remember to return to this forum to discuss the review.
Peak Beam intensity measured 3600 lx @1m giving a beam range of 120 m.
There will be parasitic drain but it cannot be measured as the unit is sealed.
A very predictable runtime profile...
For the runtime graph, please go to the Exclusive Content at Tactical Reviews, but remember to return to this forum to discuss the review.
Troubleshooting
This section is included to mention any minor niggles I come across during testing, in case the information helps anyone else.
The BC30R in use
If you do a lot of night time riding, the BC30R is something you will really appreciate. Apart from the great beam, it is the OLED display and the information it shows which will make you wonder how you ever did without it.
Having a clear 'remaining runtime' showing on the display allows you to plan your ride and ensure you get home without losing light. If you are a bit late and the runtime is not long enough, drop down a level and see if you now have enough light to get back. If not drop down a level again.
Although other lights may have battery low indications, generally once they show up you really have to stop and change the batteries or risk losing light while moving. Though usually not a serious issue, you just don't get any clearer than the count-down of the actual runtime remaining.
One could argue that as the BC30R has a built-in rechargeable battery pack, that this is then a necessary feature as you can't swap the batteries if they run out. Before testing it, I might have agreed, but with this information, planning is so easy and you can adjust the output based on your needs at the time. Part of the route might need 'High' for you to see by, but other parts might only need 'Eco' for you to be seen by. Swapping between these on a standard light will mean any guess you might make for remaining runtime will be wildly inaccurate, especially if spanning a few rides. You will then end up charging the batteries more often than needed just to be safe.
With just the basic charge level indicator, you can quickly see if it is worth a top-up before your ride, then during the ride have the peace of mind it will run for as long as it shows on the display.
Back to the beam, and prior to getting the BC30R, the BC30 had taken over as my primary bike light thanks to its excellent beam shape, power and colour. Despite having a built-in battery, the BC30R has superseded the BC30 (now relegated to a backup light) as my primary light.
The more you come across other riders with LED lights, the more you realise the glare reduction feature is something all bike lights should have. Knowing that you are creating far less glare than a standard reflector or optic gives you a better feeling when you want to turn up the power. This is not just a benefit for other road users but for pedestrians as well. The trails I ride often have dog walkers on them, and some lights I've tested have them shielding their eyes, but not the BC30R.
As a right-hander, I have the BC30R mounted to the right of the stem. This places the '-' button closest to my thumb. Generally my requirement for a quick adjustment in output is to turn it down, so this fits in nicely when coming across other riders or pedestrians on the bike trails.
The first few times I went out with the BC30R I used the remote switch, but more recently I've not bothered with it. It is useful to be able to flash up to maximum output (though only for 20s) but less so than I originally thought. The main annoyance is that you have to unplug the cable when taking the BC30R off your bike, and if you are leaving the bike locked up outside you may want to take the switch off too. After doing this a few times, I found the benefits were outweighed by the bother of connecting the switch as you have to do it before sliding into the mount. For a fixed off-road rig where you don't have any security issues, I would use it, but commuting or rides with stops that require the bike to be locked up, it loses its attraction.
One particular part of a trail I ride regularly has an old very broken-up tarmac section which is very harsh on lights and their mounts. Most light end up shaking round the handlebar or wobbling violently. Like the BC30, which uses the same mount, the BC30R takes this in it stride and doesn't budge or vibrate.
When fitting the clamp, the screw is very powerful and does cause the mount to rotate around the bar slightly as it gets tighter. Getting it to be in the right final position took a couple of attempts, but once fully tightened in the correct position it is not going anywhere.
It has surprised me how easily the BC30R has overcome my general dislike of lights with built-in batteries, but that OLED display has made all the difference.
Review Summary
______________________________________________________________________________________________
Things I likeWhat doesn't work so well for me
OLED display showing remaining runtime.Built-in battery.
Shaped beam.Remote switch can become a nuisance to fit and remove.
Neutral white beam tint.USB port cover rubs off black marks
USB charging.'+' and '-' symbols difficult to see.
Solid, Quick-Release, bar mount.
Low glare.
1000lm continuous output.
Derek Dean
Monterey, CA
Thanks for the review. Nicely done. Yep, while it looks like a fine light, and the OLED display seems like a definite upgrade, I won't even consider lights with proprietary built in battery packs. That's a definite step backwards.
subwoofer
Hove, UK
Generally I would agree, but I've used a few now where without the control over the power pack, the features cannot be executed as well. Think of it like the closed system 'Apple' model.
As a regular user, this light has won me over on the built in battery. For the vast majority of the bike light market, people will want an all-in-one package, and not something you then need to buy extra cells and a charger for. For the Flashaholic, this has a down-side that for many is actually a positive.
Swedpat
Boden, Sweden
Thanks for the review Subwoofer!
Since long time I have considered to get a Fenix bicycle light but this might be the model which makes me to finally pull the trigger!
N10
Montreal
Have you measured how accurate the remaining run time displayed is compared to reality? I was also wondering if the internal batteries can be charged while the light is in use. Can those batteries be user "replaced" in the event those have reached their useful life and no longer hold as good of a charge even though by the time this happens, a newer better light would probably be out there. a combination of OLED display+ USB charger and field replaceable cells would've been ideal. An extra cm length would be accceptable in exchange for those features imo..cool light still & thanks for the great reviews as always.
subwoofer
Hove, UK
Not specifically as this would just take far too long. In actual use the displayed runtime has been accurate enough not to let me down. It is recalculated every time you turn on the light, so if it said 1h30m remaining when I turn it off, when I next turn it on it checks again and might say 1h27m.
What none of us know at this point is how it will cope with the cells ageing. Will it just count down faster than real time, or will it cut off without warning?
I haven't tried this as I can see no good reason to due to it giving such a good indication of runtime, and I always have a second light. Would you strap a USB power pack to your bike? I wouldn't. If I remember, I'll give it a go next time I charge it.
I'd say, effectively no. I'm sure there are those here on CPF who would happily fully disassemble the light and do this, but there is nothing in the design to allow this to be straightforward.
I agree. If the BC30 and BC30R could be combined, that would be something special.
