Streak
I have an LED emergency light.
It consists of a series (24) of 5mm LED's in a series parallel configuration directly driven off a 6v SLA battery.
The battery charges via a transformer and some diodes while there is mains. When the mains fail the LED's come on having been switched on by a relay. The circuit is very basic.
I want to make use of an LDR or suchlike to ensure that if there is a daytime power failure that the light will not switch on.
As there is already a relay in the circuit I guess the best would be to control the relay some how.
Total current draw from the battery is about 250mA.
Please can you give me some really simple (cheap) ideas to achieve the above?
Thanks.
Thanks.
