deejayspinz
- Joined
- Jun 19, 2008
- Messages
- 19
Sorry folks as this is not a topic based on LED lights, but since there is a lot of discussion around batteries, I thought there may be some experts here who could chime in.
Here's the deal. I was thinking of current battery powered lawn mowers and the fact that LiIon technology is not quite here yet (have only seen the Bosch http://www.bosch-pt.com/productspecials/garden/li-ion/uk/en/rotak/index.htm). The rest - are all led acid and I was wondering if it would be possible to create a 24V/36V/48V LiIon battery based on 18650's to replace those in the existing led acid types. More specifically, has anyone come across specs to create the battery setup (including wiring, protection and charger) for this size of battery? I know that I could just wait for the Bosch or newer models, but that would take all the fun out of the hack in me...
Some random thoughts:
-given the size of the battery compartments, it should be possible to wire up a number of 18650's in paralell / series configuration to get 36V with enough amperage to last. If you look at the Bosch, you can see that they have added a heat sink to the battery case as well. I can imagine that these batteries would get pretty hot.
