[ QUOTE ]
andrewwynn said:
lasted great... i had that solution for at least a month with no change in performance... when i sputtered the reflector I had left it in there, so maybe 2-3 mo. i had the rubber-band-patch with no ill effects... when i recently swapped stars.. i tried it once w/o the bands and it worked great w/o the bands so i didn't put them back in.
-awr
[/ QUOTE ]
So if I understand you correctly, once you sputtered the reflector, the rubber band LionHeart fix wasn't necessary?
