DayofReckoning
Coming from a background in overclocking computer components (CPU's,GPU's, RAM), I'm quite familiar with the massive benefits that liquid cooling components can provide, whether that be with a closed loop system with pump and radiator, or custom loop system with reservoir, versus a traditional passive or air cooling configuration.
One could argue that we are at a point now where a passive heatsink, in this case, that being the flashlight body and head, isn't capable of handling the incredible output that LED's are outputting, proof of this being the immediate output stepdown we see in virtually every high end lumen pusher that is released. We can easily make 100,000 lumens, it's the heat that's the issue. A liquid cooling solution would allow manufacturers to push the envelope even further.
Imalent has incorporated some small PC fans into some of their lights, but (1.) Performance is significantly lower than the theoretical performance of a small CLC pump/radiator (2.) Fan operation is very loud, whereas a CLC could provide silent cooling.
"Reliability" "Complexity" "Cost" etc. I'm certain these are some of the key issues that will be brought up as to WHY it's not being done. And rightfully so, it wouldn't the easiest thing to build.
But at the same time, I believe that if a manufacturer was willing to get innovative and think outside the box, I really believe it could be done.
The question is, do you think that we will see it at some point in the future?
