We tested the TIP output with an Oscilloscope. What we observed is a constant line with a small oscillating wave of 4K Hz and 5% peak up/down overlapped on it. … That, to my best knowledge, is not PWM.
Can a camera shot tell the difference between a PWM wave and a constant output with a small fluctuation as described above?
I agree that the strict definition of PWM is ON OFF cycles and that the pulsed cycle you measured is Bright Dim cycling, so not technically PWM, but still a fluctuating brightness level.
I wondered the same thing you did about the ability of a camera to tell the difference between PWM and Bright Dim cycling. Yes. I believe it can.
L > R, SC52, Quark AA, D25A, MDC AA
In the above photo notice the barely visible dots from the Zebralight, which like the Tip is Not technically PWM, it is only Pulsed.
similarly, looking closely at the scan lines of rookiedaddys Tips, they appear "fuzzy", particularly they dont show full dark segments.
in contrast to the old model Tool
I believe this fits with your observation that the bright dim cycles of the Tip are not true ON OFF cycles that is the technical definition of PWM.
Thank you very much for sharing your oscilloscope info… I will add "disputed" to my post that lists the Tip as a PWM light, as it is technically only a Pulsed light source, not true On Off PWM.
fwiw, pulses that do not drop to Zero, and are not technically PWM can still be visible to people who know what to look for (and to a camera), Pulses that are not PWM are not the same as Constant Current.. here is an example on a Jaxman E2
maukka said:
PWM/pulsing is used on low and medium. Even though the output never drops to zero and the cycling frequency is rather high at 3900 hertz, it is still possible to see when looking directly at the light and moving either eyes or the light very rapidly."
