TiN - some good feedback thus far and the low is truly low. As for the user interface - it is as easy or as complicated as you want it to be. Let me explain. There are a variety of features, much like the HDS EDC, but many of them are either toggles (turn on or off overdischarge protection), or are relatively seldom used (battery voltage check, strobe, sos) that you won't be accessing them regularly. You can program the two primary levels, and the third is easily accessible with a double twist.
If you like to fiddle with the levels a lot, then you'll find the light somewhat frustrating, as getting into the program mode takes some patience and a bit of initial fiddling. It's not the riddle of the Sphynx, but not particularly intuitive (but how many other than the U2, Titan, Proton style one level adjustable up or down really is?).
If you consider it a two level light (with third level available with minimal effort) that you can also, should you choose to do so, set the two levels to your desired points, you'll like it a lot. I have an LF2 and an LF5 and they both work well and as designed - and I use them almost exclusively as a two level light, with P1 set to around 5%, P2 to around 40% and I keep the user adjustable level set to max for the occasional burst. On whole, once set it is more user friendly than a flupic based light or Fenix (other than the L1T v2) which require multiple on/offs. Twist for P1, twist more for P2, twist twice for user adjustable (which in my case I don't do that often), twist once to go back to P1/P2.
The user adjustable mode basically is in P1 wherever you've left it (if you have the memory version), move to P2 and it will ramp up, twist twice to toggle it to ramp down and the same applies. But you don't have to do anything in this mode other than set it to a desired level and leave it there for a third level, if you don't want to ramp up/down. It does give you some flexibility, however, without having to go into program mode for P1 or P2.
On NiMH or 10440s it is a real winner and the overdischarge protection is a nice feature. The beam is excellent for this use light (I have the P4 version) and the build quality is quite nice overall.
If you like the Titan style interface - and I think you were still a bit lukewarm to it - this is not going to satisfy you in the same way - as even in user adjustable mode there is some toggling to go from ramp up to ramp down - but it isn't bad and not a bad compromise. If you like having two/three programmable levels and don't tend to want to change them a lot then it is a great light - and you CAN change it if you want to, I just would not recommend it as a frequent occurrence.
I tend to think that if I have a digital light I might as well have the option of choosing the levels rather than taking what is stock.
