Lite_me
It sounds like you have the 'Momentary On' enabled. A press and hold lights it up in your user setting, release, and it goes out. If that is not enabled, a press and hold still turns the light On, but when released it stays On.However, when I turn the light on in CUI it flashes once at me before proceeding to low. I searched around but didn't find an answer to the issue. Anyone have some insight?
When Momentary On is enabled, you get a quick flash (blink) when turning On the light with a quick press & release. I don't like that setting myself and have it disabled. I don't need momentary On, as the light is easy enough to turn On and Off. And I don't like that blink either.
To enable/disable the momentary On feature, while the light is On, 4 quick clicks will toggle the setting. You'll see a conformation flash to indicate the setting change.
Enjoy.... It's a great flashlight.
Edit: Ooops, too late...
