Liteflux LF2XT (Part 3)
Candle Power Flashlight Forum
Help Support CPF:
Status
Not open for further replies.
yea 1mm not much more than a paper clip. Well at least it has one plus an alternate atrtachment method.
+1 Liteflux
That clip is actually tougher than it looks. I hooked the clip by accident with my backpack strap by accident once while the light was in a coin pocket. Bent it about 20 degrees away from the body.
I took the clip off and bent it back and it's good as new. :grin2:
My current setup of the clip along with the lanyard (or chain)
The other AAA light in the right is the clue where my clip comes from. 😛
The wrap-around clip is stronger and more elegant than the original clip IMO. It's also nice to have both the clip and the lanyard installed at the same time. :laughing:
After 4C + PH are pressed, 2 fast blinks indicate that the ODP is enabled, while 1 slow blink indicates that the ODP is disabled.
I just received my LF2XT yesterday and I absolutely love the tint on mine..
The beam is flawless and the tint made me smile 😀😀😀
It's almost pure white with a tiny hint of warmth in it, and it makes my other lights look like colored LEDs.
He're a quick pic to compare it to my other lights:
L-R: Solarforce L2 with R2 drop in - should be a WC, LF5XT with an R2 WH, the LF2XT Q4 neutral, and Sabrewolf's 18650 edc with a 5A MC-E. Sunlight WB.
The lights are all at maximum brightness, running on Li-ions.
In reality, the WC and 5A tints are slightly less saturated than how they appear in the pics..
I don't have my LF2X anymore, but I would say that the difference in brightness is not as significant as I thought...120 lumens is plenty for keychain duty anyway.
Just to make sure I understand this correctly, if I leave auto off turned off as it comes from the factory then all other functions work 100%?
If so I can:
- Set the light to come on lowest by turning the memory off
- Reduce the number of modes to 3 Ultra low, low and 50% with press and hold for max in bursts
- Turn on over discharge for use with lithium rechargeable's
Then I will have the perfect EDC keychain light 🙂
It would be nice to have the auto off also so I don't have to lock the light out by loosening the head but I can live without it...
15 Euros for a Nano??? :faint: I have a slightly used one for sale at that price! LOL
That one took hours! I should be able to do a better one when I get some time.
Just switched from clip carry to keychain carry a few days ago. No scratches so far!
I didn't know it takes so much time!
I hope it will never scratch!🙂
:drool::drool::drool::drool::drool::drool::drool::drool: beautiful pic! thanks! it's very useful.
If so I can:
Yes, you understand correctly - you can have all that exactly using the FUI. Plus a click and press and hold will get you random strobe for giggles, without changing anything else in your settings.
I'm loving this light!😀
Ok something weird I just checked the voltage out on my DX SKU 14885 10440 charger hmmm 8.8 volts :faint: this can't be healthy can it?
OC voltage? This is an universal charger capable of charging 9V NiMH batteries, among others. As long as it doesn't try to charge Li-Ions with that voltage I wouldn't worry. BTW, recently I made some additional measurements of this charger - will post about them soon.
thanks,Yeah since that post I've figured it out,under load with a 10440 it's 4.2 volts and off the charger the voltage is 4.1 volt at the battery 😉
Status
