Dark Photon
Hello everyone ! A good year of the Tiger for you all ! :twothumbs
I bought a Liteflux LF2XT last year as a present for someone else but I wind up with it instead. It is a great little unit. I used it for about 4 months before a problem with the switch developed. :sigh: Clean, firm single presses would end up with double or multiple click actions. This would happen for several clicks and then the unit will work fine for a while. If I click it again sometime later, the double/multiple click problem would happen again.
I cleaned and lubed the threads and all O-rings. I visually inspected the unit but noticed nothing usual. I took out the circuit board with the switch for inspection. Everything on it looks clean, neat and in good condition. The switch clicks fine with no unusual sounds or play with the button. After reassembly, I did a factory reset, programmed in my preferred settings again and proceeded to used it. It did not get worse but I noticed no improvement either.
The switching is normally set in "tactical" mode. The switching problem is such that "tactical" mode is no longer reliable. I disable it and have been using that way for ~ 2 months. The unwanted multiple clicks seem more frequent now. I did not keep a count but it seems like the time between "switch malfunction" is shorter.
Have anyone had similar experiences ? A switch problem (switch circuit board replacement) ? Software debouncing problem (but it was fine for ~ 3-4 months) ? Suggestions are welcome. Thanks !
