TITAN1833
First I have to say I'm impressed with the build quality from Liteflux,the anodizing is perfect the machining top class best bang for the buck IMHO 🙂
All threads are smooth and ample,ok it's not as robustly built as say the Ra but! I can see the LF3XT being just as reliable.
One thing about the LF3XT if it has a switch failure it wont be so hard to repair as you can access the micro switch very easily,something you cant do with the Ra.
Now the beam profile the LF3XT puts out is IMO just perfect,yes I know some Ra owners wont like this but! I think the LF3XT is just as good in this department,and maybe better over all BTW that's JMO
To me the LF3XT feels very solid in the hand and surprisingly "being straight bodied" it has good grip feel to it and feels secure.
I kept the best till last that's the UI straight out the box within seconds I was able to use this light in CUI,and kudos to Liteflux for doing this :twothumbs one click the light comes on press and hold and it ramps up,click again and press and hold it ramps down perfect!
From on click press and hold and it goes to max,you can set from on any level you like,so next time if you want very low just ramp down to low and turn off,max setting is always just click press and hold away :thumbsup:
For now I wont even go into the full-function UI as it's recommended you get used to the basic one first,but hey! the basic UI may suite you anyway it's nice and easy IMO.
I'm not going into the thing is it better than the Ra or Novatac period,but if you asked me is it as good well! I would say you can't go wrong and I would recommend getting the LF3XT as an alternative.
Let's put it this way I have owned all three and all three have their good bits and bad bits,so take your pick anyone of these three are fantastic lights for EDC the hardest thing for most would be choosing one.
If anyone is thinking of maybe getting a LF3XT I highly recommend you do,it's simply that good, well done Liteflux fantastic little light :twothumbs
Now some pictures it's mandatory here on CPF 😀
comes in a nice wooden box with lanyard,tub of lube and spare o-rings
Nice knurling offers good grip for a small light.
Nice frosty op reflector for that perfect beam :twothumbs
down into the led looks perfectly centred.
tail standing perfectly :thumbsup:
the tail end showing the tack switch button
Nice smooth beam
Yes I know I'm late to the LF3XT party but! better late than never.
Nice smooth beam
however I'll play some more with the CUI before I venture into FFUI after all I want the honey moon period to last a little
