geepondy
lithium AA\'s vs. alkalines-OK to use litium\'s in turtlelite II?
I've been doing a little experimenting with my AA CMG Infinity flashlight comparing light output with a lithium battery vs. a alkaline battery. The lithium battery has already had quite a bit usage in my digital camera and is a Eveready L91 E2 photo lithium battery. The Alkaline battery is a standard Eveready alkaline, not the titaniums. The used lithium battery clearly produces a noticable brighter light then the alkaline. I have heard here that at least some lithiums have a 1.7V rating as opposed to the standard 1.5V of the alkaline. This lithium however at least in print on the battery gives a voltage rating of 1.5V. Upon measuring the open circuit voltage of each battery, I get 1.58 for the lithium and 1.57 for the alkaline. Does eveready produce another AA lithium battery rated at 1.7 volts or where did the 1.7 voltage rating come from? The lithium battery will stay in this infinity, my question is, is it safe to put four lithiums in my turtlelite II? I don't want to harm the light but clearly would appreciate it if the lithiums can provide an extra punch. If someone could explain the 1.7 voltage rating of lithiums, I would appreciate it.
