Lithium Ion AA size, charger?
Polar_Hops
Hi, I was wondering if there was a place where i could get a lithium ion in a AA size. You see, i want to try to use it for a pill (lambda's minipro) when it becomes avaliable, and I'd like to have it running from a cut down minimag.
I think this should work. I just dont know HOW to charge them.
Also, since the pill acts as a booster, it will probably drain the cells beyond their critical discharge point, where it damages the battery. I have a set of pilas. Does anyone know if there are protected cells (from overcharge and discharge) in the AA size?
Thanks for any help i recieve!
you can buy pre-fab chargers.. if you have soldering skills you can buy the charger chips and build one.. i will sell a 'DIY' kit for LiON charger for $10..
http://charger.rouse.com will show you the charger you can make and the directions so you can see if it's beyond your capabilities.
-awr
[ QUOTE ]
[/ QUOTE ]
4sevens has a real good deal for them, $6 apeice. I can't even beat his price /ubbthreads/images/graemlins/blush.gif
I also have the modded charger and AA Li-Ion if you need. You can get them here.
Modded Li-Ion Charger & 2x 14500 Li-Ion ($30)
- capable of chargin R123, 10440(AAA), 14500(AA) Li-Ion
14500 Li-Ion cell ($5)
