artar & robo,
cutting them apart is no problem. i cut about 50 223 duracells apart last night as a matter of fact. all u need is a sharp razor knife and maybe some needle nose pliers. you cut the bottom off w/the razor then u can pull them out by the little tab that runs from one to the other. then use the pliers to pull the tab off each battery and wrap each one in a little tape. now you got yourself 2 cheap 123's. good luck
-Eritt
